Its not a Wednesday but will update with more info i have.
Suspension. I've put alot of time into this, adjusting, testing, adjust more, test. Hopefully it can also help someone else. Or one of you guys can try it and post your thoughts.
Basically. I know everyone wants different things from a bike. But overall a road bike has to work in a wide range of situations. The factory set up felt like the bike had a great chassis but was just not set up. The Suspension is basic but it works which is surprising. From factory it has a bit of front preload, zero rear, and damping is kind of close. The clickers say rebound. To me they seem to effect overall damping also, not just rebound. Like a needle closes everything. A Matris or Ohlins shock is €13-1500 and for sure will make a huge difference but personally I think its not needed.
This is why I'm posting this stuff and try to help. Road guys crash quite alot. You see videos of guys just running wide, not turning even in basic corners. Sure this is rider. But also I sympathise because alot of it is bike. On 2014 when I was moving from KTM to a 600 I test rode a CBR600 road bike at a dealer to check it out. Brand new bike. It was a crash waiting to happen. Front and rear were like two different bikes. Front collapsed on braking, rear was way too hard with no damping. Bike wouldn't hold a line through a corner. Couldn't add throttle at lean. It was a big eye opener.
So as I said. Factory the chassis is good but settings felt off. Initially to make it turn I added rear preload. Improved. Then removed from front. Improved again. Moved clickers to suit. And left it. Issue is I never measured the bike and it was a big Band Aid. The forks has too little preload and were sitting deep in the stroke. It turned well but it did fall on its face a bit on braking. Held a line but I had to use alot of back brake to kinda "pinch" it. Basically ride around it a little.
I've been changing and trying things. Every change I made i left a voice note in AI with the exact change. Then tested it and immediately stopped and left thoughts. Just kept that AI chat going all through the changes. Then after the end asked it to make an image summary of my bike vs standard using everything I've told it over the past few weeks.
Rear- Its workable. Its ok. I like to make things do what they have no business doing. Like racing the 990 Superduke, (just with spring and valving changes) against a field of Ohlins shod GSXR 750's and 675 Triumph Daytonas and beating them. It 100% NEEDS rear preload. I've searched youtube and images. All the bikes being reviewed have zero rear preload. No rear support. No way the bike will turn or exit well. Damping isnt great bit it can do juuuuust enough to work.
Front- This was my issue. To correct it I added preload. Which then puts the bike out of a good window. I read a set up from MH Racing where I can see the guy set this bike up to numbers and not riding it. Lots of front preload to get forks in the number range (9.5 turns!!) This does help the forks. But the bike is not balanced and doesnt turn. I ended up on 7 turns in. Then had to gradually drop yokes on forks. 5mm each time. 1 line is approximately 5mm. 10mm through was good. But just at the mid to end of the corner it needed held a bit, and small pause on roll on as the front felt like it was running wide. Guys call this understeer. I dont see it like thst as understeer to me is the front tyre physically sliding across the surface. Just moved a little more to 13mm through and its alot better.
Played with damping to suit. Actually more preload needs more damping. But I actually started winding some off as it was a bit harsh at times.
Most of this probably wouldn't be necessary if they released an S model with the Electronic Ohlins. But we'll work with what we have.
Bike is alot better. Mainly on braking and entry that difference is big. If feels like you have something to push against now if that makes sence. Like you can push into the fork and feel it work and push back. Mid corner is much better also. Exit is improved but it was quite good before. Overall bike feels similar, familiar, but different.
Two big unforseen results. Now it needs much much less rear brake from tip in to mid corner. And rear brake makes less difference. But exit drive and feel for the rear has changed. On paper no way this would be an outcome! It has more rear feel and can pick up the throttle a tiny bit earlier, but drive harder, roll on faster without having to stand it up/ pick it up. On app data can verify it- 49 deg lean mid corner last night but full gas 100%throttle from 42 onwards. Repeatedly on many different corners. When rear moves its still nice but just better. More controlled. Progressive then obviously because shock is budget it has a little pump.
Here is the AI image of standard vs mine. Feel free to try it or ignore it. Whatever you want. But for sure there is no point in doing all this and keeping it from other owners.
I have a clip from the KTM where it exits like the Stelvio. To show what I mean
