My HP2 clocked 18500 miles this morning. Now got two choices as my HP2 is running out of its two year warranty period end February.
1. Keep spending between £200 and £300 per service and renew the extended warranty every year
2. Do the services myself and save up for a decent work around with proper front suspension which is the only reason I would renew the extended warranty. I average about 280 miles a week at least so minimum will be doing two services per annum.
What is your view on this and take into account that as long as I don’t wreck the bike will be keeping it indefinitely. I priced up a general service looking at my last 12k service which was basically oil + oil filter from what I could gather - £240. Suppose they looked at the valves and did a throttle body sync although the fact that I had to point out the front forks that was buggered and a problem with the indicator switch makes me wonder if they actually touched it.
I am not sure how different the valve setup and throttle body sync is between say the 1100GS, 1150GS and the 1200 so would be browsing the internet for information on this now. I am very familiar doing it on the older airheads so unless something drastically changed can’t see it to be a problem.
Rear Bevel drive – I read on the forum that some guys do actually drain the oil and replace even though it is a “sealed unit” Anybody experienced problems with rear bevel drive failure on the HP2 yet? Again looks fairly easy to drain and replace the oil so probably something I would rather do every 6k miles.
I have ordered the following stuff for my 18k service
Set of brake pads - £30 (mine is believe it or not actually still ok and on the original pads after 18k miles!!)
Washable Unifilter - £60
Oil filter - £12
Engine Oil - £25
Gearbox Oil 80W90 GL5 4 Litres - £20 (Might as well buy bulk for next time)
I would need to either make or invest in a carb balancer. Twinmax is selling for around £56 and a pretty good investment for the future http://www.twinmax.co.uk/acatalog/twinmax.html#atwinmax
I already have a oil filter socket even though from memory they only cost about £10 or something.
Obviously there is a host of things to check i.e. play on the wheel bearings, head stock and the general stuff we should be checking anyway but still looking at a total of £213 including the oil filter tool and some of my time doing the actual work. Am I missing something or what except the spark plugs that is still running perfectly fine? This cost will be down to around £40 next time as all I need to do is buy another oil filter and oil.
Looking at what Wings done with his HP2 makes me realise the only bad thing currently is the front forks but again pretty sure there is a good solid solution for this going forward. I don’t expect it to be cheap but will transform the HP2 in the best bike I have ever owned and ridden. I feel the same about my R80GS which is 20 years old this year and don’t regret for a second hanging on to it for so long. Sure it is not perfect but it certainly is much better than anything else that floats my boat.
Any comments, suggestions, piss taking etc welcome as always!
Oil filter - £12
Engine Oil - £25
