Waypoints dissappear
autogs
bookham,surrey
So using mra app,when on the Web based route planner the route is start and finish with all the waypoints I have inserted into the route.
Open the route on mra app and just shows start as 1 and finish as 2,no other waypoints shows, so this morning headed out and it got me to destination but not the route that I planned lm assuming because no waypoints even though waypoints on the original route,wtf am I doing wrong?
Sent from my SM-A236E using Tapatalk
Were they shape points instead?
Can you share/screen shot the route?
Here you go,it changed route?
I thought hands were via points?
Yep made it public,press share, says press ok to share then it dissappear!
Sorry IT def not my forte
open up 'page menu' and you see this;
select link, and it pops up with the link you need to copy
I'm on the phone doing it,when I press share and press copy nowt happens!
@OP, have you been onto the MRA forum and (a) searched or asked for help (b) watched any of the videos that explains shaping and via points. I can't help as I have never experienced your issue, all the routes I have in my route lab can be navigated by the app. I do use via points though as only using shaping points means if you get off route the nav app will recalculate the route using the preferences selected. If you have via points and you go off route, the app will nav you directly to the next via point, then follow the route as normal.
on my phone/app it brings up multiple options; sharing to whatsapp, email, copy the link etc.
Not sure if this will help but have you updated the app? Even though mine was set to auto update, I still had to go to the store and physically select the update.
Yep get that,but no option to share with Tapatalk?
Ok thanks I will check
you should be able to select "link" which copies the weblink (URL) to your clipboard. You then go to Tapatalk and paste the link into the text box
