Got my XCountry back home, in van as wanted to check it over before riding far.
Seems that the handlebar end weights have been removed at some point, probably to allow the fitting of aftermarket heated grips. On my 08 XCountry I had Touratech hand guards, which look rather like rebranded Barkbusters.
What handguards fit well on an ABS 07 model?
Also the fuel warning light is apparently not working, comes on with the ignition but apparently not when the fuel is low. Is this a standard quirk and what's the fix?
Got a lowered Hagon shock on, not sure what they're like, any thoughts?
) so this may be an option.
