Up to 190-200 km/h with aluminum cases and top box everything is fine... The lids of the boxes say180 km/h/110mph max.Lawyers...
Above 120 mph things can get "interesting";..especially if the pavement is broken or in sidewinds... The 1250 will do 142 mph on the dash with 700 rom to go ! Without boxes theoretically 150 as it will go up to 9000 rpm but power is dropping off around 8000 rpm. Nothing a slighty longer trail ighter 17 inch wheels to gain back quicker steering and a 150 Hp/Nm 1400 cc boxer could not fix....
Until then maybe the regular GS that has 5 mm more trail is the answer.But it also comes with the penalty of softer springs and 20 mm less ground clearance...decisions,decisions !
Who has experience with a adjustable steering dampener on the GS ?
Ohlins does not make one.Probably for the reason that it does not make a difference...
Maybe the Conti Trail Attack 3 will cure the problem...
Cheers...
Cheers...
