keavze said:
well..., anyone want to enlighten us about the top speed differences
between '6' and 'E'...?
Well, I'll have a go but I can only guarantee the figures for the "E" box . . .
The ratios for the "E" box are, per 1,000 revs.
1st = 7mph
2nd = 9mph
3rd = 12mph
4th = 14mph
5th = 16mph
E = 21mph
So, if you're doing 5,000 revs, that'll be 60mph in 3rd, 70mph in 4th, 80mph in 5th, and 105mph in "E".
Theoretically, then, at redline of 7,500 revs you should be able to do 158mph but you can't because the bike won't rev out in "E" much beyond 6,500 revs. Redline in 5th is 120mph
The ratios for the sports box are the same as above (I believe) but 6th = 18mph. This gives a theoretical top speed at 7,500 revs of 135mph which is easily reached. In actual fact then, top speed is about 135mph for both boxes (but the theoretical limit for the "E" box is higher).
It's possible with the "E" box to exceed 135mph (downhill, no headwind, tucked behind screen etc because the lower final drive ration allows the faster rotation of the rear wheel without the engine over-revving) but throuhg normal acceleration it doesn't reach 135mph as easily the "6" box. The "6" box bike and even the 1100GS will start to pull away from the 1150GS with "E" after about 110mph.
In real everyday terms other differences are probably more relevant: at a motorway cruising speed of 84mph, you're doing 4,000 revs with the "E" box (with a non-cat Y-piece and race can I find there's still plenty of pull from here to pass traffic); with the "6" box you're doing 4,666 revs (the bike is closer to its powerband and will accelerate easier but you're getting closer to its vibration point as well so it's less relaxed). Push on to 4,500 revs with the "E" box and you're cruising at 95mph (100mph reached at about 4,750). But with the "6" box you're at 5,000 revs by the time you reach 90mph and over 5,500 at 100mph. Draw your own conclusions.
Simon E.
PS Yes, it's generally accepted that the GS speedo and tacho is 10% generous . . . so the top speed of 135mph is a real world 121.5mph
