Are we saying that the forward and backward movement of the rack in the housing causes this excessive wear? Unless I'm being a bit thick, the pinion only moves a few mm to engage and disengage the clutch. This tiny movement can cause so much wear and then failure? Seems hard to believe. Can anyone confirm this? Prepping for a Siberia trip this summer so
Yes. My clutch cover wasn't worn badly, in fact there was only slight sideways movement in it , but after wrecking 2 sets of shafts in quick succession, i didn't want to risk it.
Since changing the cover i haven't had any more problems.
Believe what you like, a clutch cover is around £70, as are the 2 shafts that will need replacing are also the same amount.
If the shafts do jam up, as mine have done on 2 occassions, it will be a workshop job to remove the clutch cover. it can be done by the side of the trail, but it's not what i'd term "mechanically sympathetic"
