Garmin Basecamp
parkys100
Southampton,England
Hello just bought 350LM with basecamp software and when planning aroute on the PC when using the new route planning button (R)'when it takes me down the wrong road and I want to delete the last route point it completes the route.On Mapsource a right click gave the option to delete the last route point.I know must be simple?but what am I doing wrong?
Can you use the edit button from the tool bar?
■Click Edit, and select one of the following options:
■Open Selected Item: View detailed information for selected data.
■Undo: Undo the last action.
■Redo: Redo the last action after you have clicked Undo.
■Cut: Cut the currently selected item and place it in the system clipboard.
■Copy: Copy the currently selected item and place it in the system clipboard.
■Paste: Paste information in the system clipboard to the currently selected location.
■Delete: Delete the currently selected item.
■Remove and Delete Unique Content: Remove the selected list or folder and delete all items that appear only in the deleted lists.
■Remove: Remove the selected list or folder.
■Remove from [name]: Remove the selected item from the current list.
■Duplicate: Create an exact copy of the selected item.
■Rename: Rename the selected item.
■Select All: Select all items in the Library, in a list, or in a device.
■Send To: Select a Library location or a device to which you want to send the currently selected item.
■Move To: Move the selected list to another folder.
■Advanced: Use advanced editing options for routes or tracks.
■Geotag Photos Using Track: Add geographical information to photos taken while recording a track log.
■Properties: Show the pop-up balloon and display the properties dialog for the selected item on the map.
■Options: Set your application preferences.
