Gear Change lever adjustment
RichieS
Guildford , Surrey
I've had a search but cant find anything......Is there a way of adjusting the gear lever on the HP2E.
Got new boots ( Thanks Skippy!) but i could do with moving the lever up a tad to get the boots underneath
Ta
Richie
hi Richie
I had the same problem :
you can do it your self , but it is a heel of a job :
not difficult , but stressing , because the is no room in order to un screw the small toex that is fixing the gear lever .
you have to follow the gear lever near the motor , then you will find it m.
good work .
Ciao Renato
Ta
Richie
I haven't moved mine but I have found that when wearing MX boots that I often end up changing up with the side/edge of the sole of the boot rather than trying to get my foot under the lever. Given the restricted articulation of MX boots, even if there is room you still end up having to move your leg a lot, which is even harder when you're standing!
Try the side of the boot - from the sounds of it, might be easier than adjusting the lever!
