handlebar mount to go on Garmin 2610
mark2jag
Camberley, Surrey
can anyone help please. I have a Garmin 2610 and it has a c shaped bracket in which fits the garmin itself. On the back of that is a Big ball on which i think a handlebar mount should go. Does anyone have one for sale?? PLEASE.
Ta very much.
Ta very much.
The C shaped plastic bracket could be RAM-HOL-GA9 and the ball on te back is RAM-B-238 diamond base.
Arm (3") is RAM-B-201 and u-bolt is RAM-B-231Z and has shim to sit inside u-bolt so suits rails from 1/2" up to 1.25"
Mark,
The cradle image is RAM-HOL-GA9 so should have a diamond base ball (RAM-B-238) on the back, so to complete, as before .. Arm (3") is RAM-B-201 and u-bolt is RAM-B-231Z and has shim to sit inside u-bolt so suits rails from 1/2" up to 1.25"
*IF* you have no balls attached (pun intended cos I'm officially an ol git :rob) then all three mount parts are in a kit, RAM-B-149ZA (has short 1.75" arm) or RAM-B-149Z (has 3" arm) and should save a few beer tokens buying this kit
Depending ...
... on where you want your Satnav to sit I can recommend the replacement handlebar clamp bolt that incorporates a ram ball. We've used one on Jaq's F650GS (Twin) and it offers a much neater solution than the 'U' Bolt types.
