Help!
Tyddewi
West Wales
How do I turn off/remove the flat tyre symbol on the TFT screen?
My tyres were not at the correct pressures, warning lights came on,and flat tyre symbol. I stopped, pumped both tyres to required pressure, warning lights stopped, but low tyre symbol remains!
I rode 200 hundred miles tyre pressures remained constant, warning message and warning triangle removed, but flat tyre symbol remains.
How do I get rid of it?
No Idea, but spec the vehicle in question and I am sure someone will be along.
PS Try Grok...although be prepared for a wrong answer :D
Hi, it should clear itself when the tyres are pumped on and the bike is ridden.
Barry
you need to set the tyre pressures cold, taking in account the ambient temperature. If you have been topping up a hot tyre then the ambient pressure will still be low
the TPMS uses a reference temp of 20C ambient, or it did on my R1200RS.
Don’t you just need to push the wheel on the left handlebar to the left to cancel.
I rode up a kerb 2 years ago and the light came on, according to the info on the NAV6 i had 5.1 bar in my tyre!
Anyway i rode on and after about 15 minutes it cleared itself.
Just check you haven't over filled.
By riding it a few minutes, it should clear itself out.
Also, on the 1300 you can also disable the tyre pressure monitor warning from the settings.
