help
fatgser
london
:blasthi
just got my 1150
like a total nob have only just noticed clutch level v low
is it worth topping up or is this better to take to a mechanic??
the abs lights wont go out either i thinks ive been mugged
any advice would be great cheers:beer::beer:
Double check the level Fat. It could be over filled, have you got the reservoir properly level? can you see air? If it's definitely low the top it up. It's easy. Use correct screw driver though, the screw heads are easy to mash. Some WD40 overnight will help.
ABS lights could be a number of things. Broken wires, sensors not working or spaced properly. Let the dealer fix unless you know which end of a screw driver is which :)
1150
Can't really help you with the clutch issue, but the ABS lights fail to go 'off' if the battery is not in good condition. If it is not holding charge, or not been charged for a while it does not have enough juice to run the diagnostic tests.
Charging the battery should help you check it out, while you are at it, check the level in the battery, as the battery on the 1150 is under the tank and therefore a pain to check it often goes unchecked for a long time. A lack of fluid in the battery would be all you need to cause the problem with the ABS not setting itself.
If you have bought from a dealer take it back and get them to sort it.
Chris
thanks mate
:thumb
tried the reset method from thread (earthing abs on diagnostic connector under seat)
ABS IS NOW WORKING:beerjug::beerjug:
