Gilson said:
Mags say the GSA is a bit faster top end, but what is the difference on the roads?
Yeah, and yellow bikes are faster than blue bikes too!
Gilson, I think that the question has been asked several times before - you could use the 'search' facility to see if you can find a recent thread.
However, to start you off, the 1150GS and the Adventure have, to all intents, the same engine. The Adventure does, however, have a fancier blackbox which allows a factory supplied plug to be inserted so that you can run the bike on low-octane petrol, parafin, chip oil, porridge and cocoa.
The gearbox ratios may be different depending on the original owner's option choices.
The GSA has longer suspension travel and has a higher static ride height.
The GSA screen is a little wider (still not much good, though).
Most GSAs have a single seat, whereas the GS has a separate squab for the pillion.
The GSA has a big tank option although I believe that it comes as stock now.
Factory luggage and engine bars are different, but standard GS parts will fit the GSA (but not
vice versa).
Some other cosmetic and minor differences.
Whichever model you get, black bikes are fastest
Greg
