WaterMonkey
Does a new engine come with a new clutch and gearbox?
Also do they come with the new heavier flywheel?
Usually yes. You can get a 'short' engine with some models but in this case i think not.Does a new engine come with a new clutch and gearbox?
have replies to this in my NEW ENGINE thread.Hello guys and girls! I could do with some advice?
BMW have come back today and my 2015 GSA (5k miles) is going for major surgery! New engine, drive train and bevel!(Corrosion)
For those out there that have also had this what exactly is the process? ie when they change the engine I take it that they issue some paperwork to prove the mileage ect?
How does it work with your servicing schedule as clearly when the bike is due a 6k service the engine will be needing 600mike service! So what about 3 years time when it needs its 24k how will that work out as the engine will have covered 18k!
Sorry if it's a daft question just no idea how they play it!
Many Thanks
Anyone had one done under the extended warranty? Mine's got some starting to show
I read that all the corrosion issues were because they paint the casings then machine the mating surfaces and this leaves bare metal for the damp to get under the paint I dont know if this is true or not but if so would sealing all the joints when new with some sort of clear sealant help reduce the risk
Probably right, on the black engines it is obvious that the cases have been painted and then the areas where fixing fasten down onto have been milled back to bare alloy
I am getting a replacement engine in a 2014 1200GS TE. Manufacturers warranty ran out in March 2016, I bought the bike in October 2015 with a 12 months BMW approved warranty. I was told it would be a 'good will' gesture as it was out of the manufacturers warranty period. Also having the final drive casing replaced as that is suffering the same problem.
Ok, so only 9 days after taking it to dealer to look at problem it is coming back tomorrow with a new engine fitted.
It is coming in a van.
I have to be honest I'm not keen on riding it, in fact I just want to sell it, thoroughly disillusioned with the whole BMW experience, it was my first brand new bike & I'd planned to keep it for many years.
What's the problem ? Just ride and enjoy your "new" bike.
Mine is an April 2015 bike too with over 16,500 miles on it and not one spot of paint bubbling (yet, touch wood) I have ridden through two winters too - I wonder what the root cause of these paint issues really is? I am pretty fussy about cleaning and liberally and carefully apply FS365 to all painted surfaces.
