Jeeeeez
I was at the beginning to balance my throttle bodies on my 2010 gsa (something i have done fine a few times on my 1100gs) when i noticed that the screw that adjusts the throttle cable on the left side was weirdly loose in the housing, on closer inspection the adjuster bolt has sheared in its housing.
It was still running ok before i started the sync, just a little bit out... unfortunately i had loosened the right side off already - (so no easy way to get the right side as it was before, left side is locked as its sheared).
I tried to start it anyway... rough coughing as expected and didn't fully start. tried to adjust the right side to what i had (mental picture) originally... tried to start... coughing but no start...
finally it wont fire at all....and the left side (i'm guessing tps) makes a nasty noise
thats it then im stuck...
any suggestions where to begin, how to replace the cable or why it wont fire at all now.
