Computer connection thingies, don't worry about it, just tuck them away from the wet. I think these were on the export to USA version. Mine has a smaller one that clips into a clamp under the rear seat.
One is for an option for california which is an air bleed system connected thru the throttle balance take offs the other I think is for authorities use possibly a foglamp
For the last time - One is for a CO pot. Later bikes have a lambda but the plug remains on the loom.
The other is for the american market, emissions, charcoal canister.
Yes stil required on a non Lamda sensor bike it is what controls the mixture at idle!So is the CO Potentiometer necessary on an 1100 with Y piece and Remus?
I went to have my TPS setup by the local ind BMW guys and they spotted this was missing on mine (oops....left it on the old/outgoing loom), they said they need it to set the bike up properly?
My '99 1100GS is a German import - with a CAT - and I have these two connectors - but no CO pot - anyone else with an Import, or know why the pot isn't fitted to this model?
Mike
If you have a cat fitted you must have a lambda sensor. Which does away with a CO pot.
