Parcel force twats, it will be £5 tax and 20 quid fucking admin charge, robbing bastards
That's why more stuff is being opened, couriers make a fortune in admin costs, I wonder if they would release that information under FOI act?
LC GS 2017 K50 - used C spacer, although you can confirm this by measuring as Roadlok suggest.
Just wanted to bring Roadlok users attention to this issue I had.
My Roadlok over winter was exposed to salt.
I went on holiday in February this year for 2 weeks in the sun, back home my Roadlok locking mechanism siezed.
The barrel mechanism was freed with WD40 temporarily, but the lock barrel had jammed so it wouldn't release the plastic round dust guard.
Luckily, I hadn't used the locking pin.... or it would have jammed in situ with no easy way to release it.
I contacted Ian at Roadlok who asked me to return the faulty jammed unit, and he sent me a brand new unit free of charge.
Excellent service.
BUT.... be wary of the barrel jamming with corrosion and don't leave the locking pin in for long periods of time.... would be my advice.
Mine was also seized in a few weeks ago. I’ll only use it when I park up away from the house in future .
As has been said already, give it a clean and lube every now and again......![]()
As there is no instructions for the roadlock, you don't have to take the bracket off the caliper to remove the barrel .I did here but just in case as its not obvious for the non mechanically minded
To remove the lock
barrel (lock cylinder):
1. Turn the key to the fully unlocked position.
2. Insert a small allen key into the crosshole on the lock body, and press
it into the deadbolt, which will force the deadbolt to push inside the
lock cylinder.
3. Pull on the key, and the entire lock cylinder should slide out of the lock
body.
4. Clean and replace.
Just alen key for removal
Kawasaki H2SXSE
1290 Superduke GT:But gone
KTM990 Adventure (survived 3 winters and looked good as new apart from the wheels.Reliable.)
1200GS :(Rust bucket,electrical issues,brake issues)
1150GS Adventure (Broke down-quite a bit,recovered twice.)
BMW1150 GS-blue and white-all good
Honda SP1.
XT660X to much vibes for me
VFR800 Vtec
VFR 800 Anniversary
ZX6 F3
Z650
Z650 (Broke it)
MTX125
The face of my lock barrel has gone black! Roadlock say they’ve never hear of this before (I can’t believe I’m the only one - anyway, I quite like it).
My lock became hard to use too so I removed it from the bike, sprayed the lock with brake cleaner, gave it an oil bath, repeated the rinse, dried it, lightly oiled it and replaced.
Previous advice about graphite dusting worked to a point but the first spraying came out very black!
Thanks for your post Zoton, it’ll be a lot easier in future although I do put a disc of Helicopter tape over the wee hole to stop crud ingress which I’ll obviously need to remove first.
There’s no substitute for regular, preventive maintenance.
Pas d’elle yeux Rhône que nous.
No you don't understand what happened here.
The pin you are pushing back in your pictures with the Allen key, had jammed and wouldn't move. So you can't remove anything to get access to it.
You can't release the plastic dust guard, or the locking pin (whichever was in situ at the time).
You can turn the lock barrel with the keys inserted (full lock rotation left and right), but that pin does not move - it's jammed. Thus locking the whole unit to your bike !!
In normal operation, when you turn the key in the barrel, it retracts that pin so the dust guard or locking pin can be removed. If it corrodes over a couple of weeks that pin jams
As it did with mine. Luckily I only had the dust guard in situ, and was able to unbolt the whole unit without further damage.
But even then, you have NO ACCESS to that jammed pin to release it... unless you drill out the dust guard (if you were lucky enough to only have the plastic dust guard inserted)
Oh my god, can you see any corrosion yet?
I did Shaun. Not after every single ride but I did clean it with water and compressed air.
I never used any lubricant as it was suggested by Roadlok not to.
But I seriously think during winter you should take it out and give it a good clean. Especially if there are any signs of rust in the barrel.
Problem is it is very exposed where it sits to all the crap being thrown up on the bike.
Really needs a neoprene (or rubber innertube) cover for the actual lock mechanism, or something similar during winter use to keep the crap off it.
I just had an idea.....
I've cut up an old inner-tube from my Africa Twin front wheel (had a puncture last week).
It's stretchy but robust.
Use that to cover the lock while it's on the bike in winter and when washing it.
Maybe??![]()
Kawasaki H2SXSE
Honda SP1.
VFR800 Vtec
VFR 800 Anniversary
ZX6 F3
Z650
Z650 (Broke it)
MTX125
Oh... ok![]()
UKGSer is....
"A vent, a source of info, a source of bullshit, a source of humour and in the coming months, possibly a source of sanity." Big Lad March 2020
"I have always known this community is full good people even if most of you cover it up with piss n vinegar" Chad 2018
"Its about being a grown up hooligan - and if that means a dark visor, remus open pipe and a bit of speeding out of town then all well and good" Kaister 2005
