Posh Pete
Still got a pulse.
Not sold yet? Or reluctant when it comes to the deed?Got just the thing for you……
I haven't got a lot. I have a used set of barrels and pistons that I bought as spares. Most bits I bought were used to replace the less good bits on the bike I have. In truth, mine has been untouched for a while. While it's been running it needs a bit of fiddling with ignition and fuelling.
You could go 'custom' and fit an 860cc kit from Siebenrock.
Oro Metallizzato: 860cc BMW R65LS Custom
Flashbike: An exquisitely modified "860LS" hits the BaT auction block... In the late 1970s, a new term was coined for the bold breed of motorcycle leaping onto the scene, with radical style and high performance, filling the glossy pages of the era's magazines and the odd Milanese or New Yowww.bikebound.com
Sorry. No. I haven't got them on my bike at all. I was missing a fairing mount bracket and I struggled to find one of those. Usual sources are Motorworks or Sherlocks. I think it looks OK without them. Why not just take the lhs one off?Do you have a RHS front fairing infil panel or do you know where I might get one ?
Decided to sell this to make room in my garage so I can work on my sons new to him R100GS
For Sale Thread 'BMW R65LS'
BMW R65LS
Manufactured in October 1981 and first registered in August 1983
V5 shows it registered as a historic vehicle so no Road Tax or MOT
Mileage shows as 50,500 but no MOT history to back this up
I originally bought this with the intention of doing a sympathetic restore
Plans have changed as my son has just bougt a R100GS so I need the garage space to re-commission that for him
Bike has been previously re-painted , if I was keeping it I would have had this re-done
Previous owner fully serviced it : oil , oil filter , gearbox oil , swinging arm oil , final drive oil , valve...
- nicholsonj2252
- Forum: Old ads
I was just wondering whether there was a single one of your bike refurbs, that I didn't dearly want to buy...![]()
You put me in mind of a chap I once knew in Northallerton. He was a retired RAF aircraft technician. Unfortunately no longer with us, he had a passion for engineering, he enjoyed it. I was fortunate to buy a Kawasaki GPz750R1 from a fellow called Moss from Thirsk, who in the 1950’s held a number of Karting world records. It turned out, he had bought the bike from the ex RAF tech, who lived just around the corner from me. I went to see the guy, and ended up chatting for hours and becoming friends with him. He gave me all of his engineering notes and measurements from his ownership of my bike. A bike I wish I hadn’t sold.Carburettor cleaning/refurb session
Could be that someone revved the tits off it from stone cold with thick oil…Removed the old oil filter and it was completely squashed and stuck in , looks like the filter had not be inserted properly over the oil tube ?
That looks lovely John. I approve of the additionsSteering head bearings replaced as they were shot . Dropped the sump and it was incredibly clean , I think the engine has had work done on it in the past as it has stainless push rods fitted , has excellent compression and burns no oil . Final drive level plug was incorrect , a cut down standard hex head bolt so that has been replaced (threads were fine) . Side stand had been repaired poorly so re-done properly with a new bush fitted . Exhaust removed to give it a good clean . Next job is to strip the carburettors , clean them in the ultrasonic tank and then re-assemble with new O rings .
Decided to call it a day and go out for a ride on my R80GS , a bike that matches my demanding quality standards ;-)
Stuck/ jammed oil pressure relief valve?Removed the old oil filter and it was completely squashed and stuck in , looks like the filter had not be inserted properly over the oil tube ?
I’d have thought the filter bypass valve would have opened before it crushed the element.?
Take a good look down the filter canister to see if the bypass valve has been messed with.
You should be able to push on the ball valve with a bit of thin steel rod.
Probably a good idea to stick a pressure gauge on it when it’s up and running again.
Certainly a bit concerning.
Might a rubber seal from a previous filter have been left in situ when that filter was fitted?
